1 - 4 of 4 Posts
I started noticing that there's an oil build up on the shaft towards the end of the shock stroke which it never done it before. and when I check the air pressure on both main chamber and SPV, air pressure is still the same. do I have an oil leak?? should I send my shock back for warranty? or is this normal?
How much oil are we talking? Your shock probably just needs a regular service, not warranty work. Take it to your LBS (or do it yourself if you feel comfortable) and give it new seals and an oil change. Should be good as new afterwards.
1 - 4 of 4 Posts
