1 - 6 of 6 Posts
I was adjusting my rear disc brake and to test if one or both pads were rubbing the disc, I lifted the rear tire and spun it. As I watched the tire spin, I noticed that the cassette has a slight wobble, or is it the tire that has the wobble and thus making the cassette wobble. It's barely noticeable, very slight. I don't know, am I seeing things. Or is a little wobble normal?
Also, I have another question. Since most people rarely ever remove the rear tire for transportation or whatever, does this mean it or the rear skewer doesn't need adjustment from time to time? If no, how often do you have to readjust the skewer for tightness and security?
And for those with disc brakes, whenever you remove a wheel and put it back on or even when you play with the skewer without removing the wheel from the fork or seatstay, do you have to make disc pad readjustments? I noticed that I have to do this sometimes with my rear whenever I unlock and then lock the skewer. Is this also normal? Thanks!
Yes, it is normal for the cassette to wobble slightly.
No adjustment needed. You may want to check the qr to make sure it is in the dropouts correctly, but it is usually not an issue as long as you are not removing the wheel.
Yes, it is normal to have to do small adjuustments to the alaignment of the brakes. It is critical that you make sure the axle is all the way in the dropouts any time you mess with the qr's.
The freewheel lockring
could be loose. its not like it will fall off or anything but if the cassette is loose on the freewheel body it will grind into the freewheel body reducing the tolerances between their inerface.
Samsonite Tester
When you remove the wheel of a hydrolic disk brake , be sure not to squeeze the lever. The will close tight. You will need to pry them apart with something to get the wheel back in. When traveling with the wheel off in a fork mount, stuff a folded up business card in between the pads.
Take off rear wheel. Grab the axle (no skewer in) on either side. Wiggle ? Yes or No.
If Yes ; You will need to remove the cassette to reach the drive side nut. You should just have the lbs take care of it this time.
If No ; Grab the casstte and wiggle . Did it wiggle ? (axle test first) If yes then a lock ring tool will be needed to tighten the cassette.
If No wiggle again, then turn the bike upside down. Grab the downtube , put a foot on the seat , and pull on a drop out one at a time.
Get the wiggle yet?
I've had two hubs that made the cassette woble when the back wheel spun. One was new so I think it has something to do with a manufaturing mistake in the hub. Both still work to this day and they were both Shimano XT hubs. But check that everything is tight and if it is I wouldnt worry about it.
1 - 6 of 6 Posts
