1 - 5 of 5 Posts
So after a bad landing from a jump on a hardtail my back hub on my bike has been wobbly. I tightened the back bolts as tight as possible but no fix. And the wheel is true as far as i can tell. The wobbling is pretty noticeable. Is this the hub? And if so how hard would it be to self fix?
Discussion Starter · #3 ·
So its probably just better to take it into my lbs? I dont see any frame damage. It wiggles when even off the frame; I can hold it by the bolts and have someone else wiggle it.
Discussion Starter · #5 ·
I just took off the wheel and the inner nuts that go on either side of the ratcheting system in the hub were loose. I tightened those and it seemed to fix the problem.
1 - 5 of 5 Posts
