Is this a good deal?
443 Views 1 Reply 2 Participants Last post by  Swthrtsuzy
I have a line on a 08 Transition Dirtbag (large) that a guy is selling but I am not sure if it is worth it or not. New to the game so I have no idea what anything is worth. I looked up Transition bikes and they seemed like an ok company.
Wheels: Mavic XM 321 (xt rear hub, Marz 20 mm front) used but true and strong and pretty light.
Brakes: Front - Avid Juicy 7 w/ 8 in rotor. Rear - 8 in Hayes.
The avid either needs a bleed or has a pin hole in the line b/c it loses power every once in a while.
Front Der: Shimano something or other. It works.
Rear Der: Sram X-9. It has some play in it but it shifts fine.
Head set: 1 and 1/8 FSA Pig with reducer cups pressed in. I can have these pressed out if you're running a 1.5 steerer.
Bars: 30.5mm Kona (cheap but they work).
And a Raceface evolve xc crank set
Prices: Frame and rear shock only = $800. All of the above: $950.
He also has a nearly new Canfield Lucky, size large, anodized grey with blue links with a Fox DHX 5.0 coil for $1,000.
Any advice would be good.
1 - 2 of 2 Posts
Either of those bikes would be a steal at those prices. The question is going to be: What kind of riding do you intend to do? The Dirtbag is a freeride bike, and I'm going to guess that the Lucky is, too. Is that the type of riding you plan on doing? If so, go for it - whichever one feels the best and is in the best shape. If you're planning on doing XC, take a pass because the bike wouldn't be suitable for it. Good luck. :)
1 - 2 of 2 Posts
