I found this online and was wondering what you all thought...the price is $500
2007 Jamis Dakar XC - 19 inch frame. This is a sweet ride at a reasonable price. It has the following components:
• 19 inch 7005 aluminum frame, all tubes with gusseted down tube and box-section stays,fully-active multi-link design with 90mm rear travel, Fox Vanilla coil-over shock, replaceable derailleur hanger
• Manitou Slate Comp Fork, Fluid Flow damping, 30mm stanchions, external preload adjustor, 100mm travel
• WTB Speed Disc rims, eyeletted, 32H, with Shimano M65 Centerlock disc hubs, 14g black stainless steel spokes, Maxxis Mobster Tires, 26 x 2.1″, 60tpi
• Shimano Deore rear, Alivio 31.8mm top pull front derailleurs
• Shimano Alivio RapidFire-SL Shifters, 24-speed
• Shimano HG-40 cassette, 8-speed, 11-32
• Shimano M341 Crankset, Octalink 42/32/22, 170mm (12-15.5″), 175mm (17-21″)
• Shimano ES25 Bottom Bracket, sealed cartridge, 68 x 113
• ATB platform pedals, steel cage/resin body
• Shimano M415 cable-actuated disc brakes, 6″ Centerlock rotors, with Tektro ML-330 levers
• Easton EA30 MonkeyBar, 8D x low rise x 635mm wide
• Easton EA30 Stem, 6D x 90mm (13″), 105mm x 10? (15-17″) & 120mm (19-23″) extensions
• Easton EA30 micro-adjust seatpost, 350mm x 27.2mm with alloy clamp and QR seatpin
• WTB Speed V Sport SE Saddle with SL top and steel rails
