Is this a decent starter bike?
3393 Views 20 Replies 13 Participants Last post by  fly4130
I’m very new to the sport. I want something I can learn on. Given the full suspension, is this a good learner’s bike for the price? Thanks!
1 - 20 of 21 Posts
I'd say keep looking. Cheap FS bikes have poor suspension that adds more weight than it does add suspension. This has a simple single spring that doesn't have any damping I can see. This is also old so the geometry etc is dated. It will work, just not very well.
If you can look for something newer and probably front suspension only you will get far better value for money.
  • Like
Reactions: 2
considering how difficult it is to track down the original spec on that bike (and where it was sold), I'm going to give a hard no. I found an old Amazon listing for it, but I dunno when it was last valid.
Amazon.com : Schwinn Delta Sport Dual-Suspension Mountain Bike (26-Inch Wheels) : Sports & Outdoors
All this screams BSO to me. And if you look at the top tube on that frame, there's a sticker on it. I guarantee that sticker is a warning sticker that tells you not to ride it off-road. Realistically, the bike is probably worth far less than $100. The "upgrades" don't increase the value, though some sucker will pay it. Just don't be that sucker.
  • Like
Reactions: 2
That thing is total junk. Find a good quality 29" hardtail to learn on.
  • Like
Reactions: 2
Yeah
Nah.
was around $570 new, worth 70 bucks today imho
  • Like
Reactions: 1
If you want to get a bike that works off road on bumpy trails get a hardtail with an air fork.
Any bike that is "one size fits all" like that one, based on looking at Harold's link, is a big NO. Worth about $50. Ok, he cleaned it up, I"ll say $70.
And:
Product details
  • Package Dimensions ‏ : ‎ 20 x 15 x 15 inches; 48 Pounds
Wait a minute, How'd they get it into such a small box??? :D
  • Like
Reactions: 1
This is utter garbage. Spend a little more and get something decent to start with. Here are some in your area:
  • Like
Reactions: 1
Go to a local bike shop and let them take care of you. Most shops should have some starter bikes to get you rolling. They can get the bike sized properly for you too. All starter bikes are in the same general category so there isn't one better than the other. I recommend locating a Specialized, Giant, or Trek dealer seeing they typically have more shops available than other brands.
  • Like
Reactions: 1
The specialized in the other post looks sweet.
Id recommend getting a little older low mile bike like that.
Dont be afraid to offer less, all they can do is say no.
And dont worry about all the details of the new mainstream stuff, wheel sizes frame angles and all the new bike terms.
Your a mountain biker!! new to the tribe!! Roll on!!
Send an update when you get your new ride!!
  • Like
Reactions: 1
Hi. So I ended up buying this the other day in new condition for $400. Pretty sure that was a good deal? It’s a 2021 Haro Flightline Two. I don’t know enough about the sport yet to see whether or not it’s worth it to upgrade in the future, but I think it’s a decent beginner mountain bike.
Bicycle Tire Wheel Bicycle wheel Bicycles--Equipment and supplies
  • Like
Reactions: 1
Straight not tapered head tube makes it tough to upgrade the fork. That Suntour is designed with a single spring for a damper, plastic not metal bushings and no adjustable rebound. Good for smooth trails and bike paths for sure. It'll bounce you on the rocky/rooty ones. That's when you find out you want stronger brakes.
  • Like
Reactions: 1
$400 is a fair deal, but you'll be upgrading if you ride much. There's no shortcuts to a proper mountain bike.
  • Like
Reactions: 1
That's a good starter bike. I wouldn't put too much $$$ into it. Just ride it and learn more about mountain bike riding. If you get hooked, you'll start looking at better bikes. You'll have to figure out what type of mountain bike want. XC, Trail, Enduro or maybe even a Downhill gravity bike:)
Gears, Brakes, Suspension, frame Geometry, rims, tires, dropper posts, shoe, pedals, etc..... all become things you'll think about.... all the time:sleep:
  • Like
Reactions: 1
Well done. The good news is it's not a BSO so you have a chance of actually liking the sport of mountain biking. That's the best thing a new-to-the-sport rider on a budget can hope for.
Once that Haro starts revealing its deficiencies (that's not a slam, all bikes have deficiencies), you'll have ridden it enough that you'll know what you want in your next bike.
And in so doing, you'll waste less money than you would have wasted if you'd just gone out and spent a ton on an expensive new bike in the first place.
Ride it a lot! Have fun!
=sParty
  • Like
Reactions: 1
Some BB7s for stoppin' and a Markhor up front would do pretty well. I bet you could find some used BB7s pretty easily as folks upgrade to hydros.
As is, this will get you riding for sure. Fix things as you need to and have fun. You will learn what you need/want for the next one. Then the process repeats itself. Sometimes in parallel, not serial.
  • Like
Reactions: 1
Thanks for the tips, help, support. I’m learning and practicing the basics so far and building as best I can off of those.
1.) I would practice shifting first. You will almost never use the largest Chainring ( the big front sprocket). A lot of people remove them and install a bash guard in place of it. You don't need to do this. Just shift between the lowest (smallest in front) and the middle chainrings. In the back, your Cassette ( cluster of sprockets), the Lowest is the largest sprocket. The easiest (quickest) way to adjust for a hill is to shift your front derailleur (left thumb) to the smallest chainring. When you head downhill or are on a flat dirt trail, you shift the front to the middle chainring. Use your right thumb (rear derailleur) to make micro adjustments in either condition. Try to keep a fast enough cadence that you are spinning, but not so fast that you are bobbing. Not to slow where you feel like you are pushing from side to side.
2.) Practice braking. Braking is very important and takes a long time to get the feel for. You don't just grab both levers. If you do, you'll end up going over the handlebars. The front brake ( the left lever) is very powerful and quick to engage. The back (right lever) is more forgiving. If you squeeze the back to hard, you will just skid the back tire. I can always tell an inexperienced rider by the wear on their back tire. You use mostly back brake with a percent of front brake. You feather your brakes, meaning you squeeze them progressively till you have enough braking force to stop your bike. On steeper downhills or situations that you need to stop quickly, move your body backwards off the seat as you brake harder. The harder you brake, the further off the back of the seat you will need to be. This is why we use Dropper seat posts. A seat post that drops with the push of a lever on your handle bars. If we go down steep hills we lower our seats so we can move way back over our rear tires to counter balance the intense braking force that wants to throw us over the bars. You may want cheap one on your new Kona at some point?
Have fun.....
  • Like
Reactions: 1
I plan on getting a Markhor. Is this a good one for the price?
That's about what you'll pay for a fork in this range. Similar to a RockShox Judy Gold RL https://www.amazon.com/RockShox-Jud...?keywords=rockshox+judy&qid=1642477255&sr=8-6
I had the RS Judy on my old Trek Marlin 6 hardtail and it worked good for trail riding. I'm 230 lbs and it felt fairly stiff as far as flexing when you hit the brakes. The air spring allows for a little bit of sag on the setup. Either way it will out perform the harsh coil spring in that Suntour.
  • Like
Reactions: 1
1 - 20 of 21 Posts
