1 - 3 of 3 Posts
To get a Park ccp 2 to remove an octalink Crank. I tried to use a couple of pennies but that was not the answer. Jim
Shimano make a mushroom shaped device that slips into the BB hole and the narrow CCP 2 hits this instead of just drilling into the hole.
I think they are readily available.
Wombat
If you're in a pinch. . .
Use a large headed 4.5" bolt to push against (you have to leave the other side's crank bolt in place). Easy to get at ahardware store if LBS doesn't have proper parktool part
FD
1 - 3 of 3 Posts
