Is there a specially designed thru axle which allows final flip lever alignment by the user? By the time I get my thru axle fully screwed in and tightened, the flip lever is not usually perfectly aligned with the fork when I flip the handle up. So I usually need to loosen the thru axle slightly so I can get the flip lever to line up with the fork when I flip it up. Do you know if there's a specially designed thru axle which will allow me to screw in the thru axle at full tightness while at the same time giving me the ability to do a final custom alignment with the flip lever?
