Is there a consensus on hubs?
738 Views 6 Replies 5 Participants Last post by  hamachi
Kings seem to be the (ahem) undisputed champion of hubs, but I was wondering what others thought are as good, or perhaps better than the Chris Kings. I am looking for a very fast engaging rear hub that is reliable and relatively easy to service. I have had CK's and they are great, but as noted in other posts they have a pretty stiff premium price-wise. While I don't mind paying for truly superior performance, I want to make sure I am not throwing away $$ for minor increments of improvement.
What hubs have the best number of engagement points for the $?
1 - 7 of 7 Posts
Check out Hope, Hadley, Hugi (what the hell is with the Hs?...)
What do you mean you "had" CK's, what happened to them?
Good question...
I am in the process of converting two bikes to disk, and my CK's are the "Classic" (i.e non-disk) version. So, while I still have them, they are not in service at this time. I will say the Chris King hubs are truly awesome and I would love another set, but I am struggling to convince myself that they are really worth north of $700 for a mtb wheelset.
CK will put on new hub shells
For much less than the price of new hubs. You would still need to get them built up, but it wouldn't be even close to 700.
I had some DT240's which had the hub shell crack (twice) in the rear.
I had a set of CK rear hubs that constantly came loose and had horrible drag problems.
I just recently got a Hadley rear hub. It's been great so far, but I've only ridden it for 2 months or so. I've heard some disturbing things lately about the reliability of the rear hubs.
I've had the freehub on some of my Shimano hubs die, but it's a cheap replacement (20-30 bucks)
Dave
Kinda thought as much. You could probably sell your current CKs and offset the price of new ones by quite a bit if you have no use for them. I kept my old classics around for vbrake bikes, so I didn't consider the King shell swap, but wouldn't hurt to ask King what they'd charge. One thing to consider with the disk hubs is the front hubs aren't convertible between 9 and 20mm (altho the 20mm is convertible to 24mm).
Colorado Cyclist can build you three different Chris King Disc wheelsets:
with Mavic XC-717 -- $616
with Mavic XM-819 -- $624
with Mavic EX-823 -- $637
1 - 7 of 7 Posts
