Are you referring to the installation? It's the easiest derailleur installation I've ever done. The b-screw adjustment needs a second person to help, or you can deflate your shock to your sag point, but other than that it's very plug-and-play. Mine was programmed to hit all the shift points perfectly right out of the box, so I didn't need to fine tune at all.
