I just did my first set of wheels and I'm so proud that I'd like to just hang them on the wall instead of ride them! I used both pitch and the TM-1 Park Tension meter to get it within 10% on each side. Very straight and true, but, the UST rims (819) sure take a bit longer.
I set the tension and it seemed good, but, noticed the tension meter seemed to have some resistance on the contact points. I decided to grease the contact points that rest on the spoke and now my reading is about 3 points lower on the meter. Are you supposed to lube those to get an accurate reading? I either have the correct tension, or, it's possibly way too much. What measurement is right??
without grease on contact points Drive side rear on 819s- 145Kgs
with grease- 100Kgs
HELP! I don't want my wheels to explode
with grease- 100Kgs
