1 - 8 of 8 Posts
video
Bike is a 2005 specialized stumpjumper fsr pro 120 with a manitou minute 100mm travel fork.
Last service is unknown since I got it used.
What can this be? Will a standard service fix this? Its not the wheel I tried it without it on.
EDIT:
So I found the source of the clunking its a thinner spring that's in the main big spring and it's a tad bit too short, so whenever the fork is compressed, it clunks. Or its the SPV mechanism opening, that probably needs servicing ?
SPV clunks when the snap-valve gets sticky. Literally just a clean out and regrease of the valve under the piston will fix that.
Those forks had a 10lb/in booster spring inside the main. It'll go quiet with enough grease. Use a lithium grease that clings well to the steel spring.
Yea it looks like it can support very little weight, so if it happens again I'll definitely take it out. Anyway there's not enough sag, and I like a softer fork.
Taking it out will move you down a spring-rate. Super helpful if that's what you're after. Best removal method is to lever the end-coil open with a screw-driver and wind the coil out with a set of needle-nose pliers.
Discussion Starter · #8 ·
It was definitely the SPV, you're right, but for my fork it was actually because there was 0 air pressure in the SPV mechanism whatsoever. I pumped 100 PSI's and the clunking went away completely.
Thanks for the explanation, it is very helpful :)
1 - 8 of 8 Posts
