some thoughts.....
CragRat said:
Well i certainly aint riding like that i think, i id be the one broken if i tried. I have spoken to the mechanic where i bought the frame, he said he would be amazed if it was a crack and that i would get a new one if it was.
The sound is best described as if some one has thrown a couple of small ball bearings at the down tube,ill keep tyring to find the bloody thing tho.
My mate is a Rally driver also, driving a Mitsubushi Evo 6 so i will try DT's advice on that.
Thanks again To DT and all, i doubt Mr Specialized or Mr Trek would have replied.
Oh by the way, its best bike i've ever had the pleasure to sling my leg over..
Remember as said already by Tscheezy, when you have metal to metal all over the bike, noise is a lot more likely to happen than most think. When you have aluminum frames it amplifies noises from parts elsewhere on the bike and can easily fake you out to where it really is coming from, it will echo. DT brings up a good one, the metal housing ferrules, I have found that particular one on a few different bikes before being the culprit so I use plastic ferrules where possible and almost everywhere, also....the quick release on the wheels. Even on my own wheels with a King rear hub. Not a loose QR but not a totally snug tension either and a little torque sent noise through the entire frame. Some forks from all the companies namely Marzocchi, Fox, Manitou, Rock Shox have not always had the best of tollerance or locktite/lube at the crown, steerer, stancion location......hence creaky forks. Crowns are another point of metal on metal. Headset spacers, etc....I have a Fox on my bike right now doing that exact thing. Quite a noisy creaking crown.
To re-iterate what DT said about housing ferrules, check out the picture on my own bike, 1 set of metal housing ferrules (rear deraileur) and 1 set of plastic (front deraileur). To test out and see how long it takes on mine to become noisy. With one set vs. entire bike metal ferrules, I can more pinpoint where it will come from. You need to go through a process of elimination on your parts first, yes its a pain and time consuming but it could point to something dangerously loose or not lubed.
With everyones' comments here, you should be able to find this noise, hopefully I've helped you a bit.
