1 - 17 of 17 Posts
I ride my 5.5 now with Mavic 717 disk and Maxxis minyon 2.35
The 717 are very light but more XC than AM.
So I want to put the 823 UTS . they are 200 g hevier than the 717 but much stronger
I ride agresive AM but don't jump more than 1 M
Feeding your addiction
yarondot said:
If I want to use my Maxxis minyon 2.35 i need a 30 rim
The 823 is actually about 300g heavier per rim, and is probably overkill for you. Like Jdub said do something in between..5.1, Syncros DS-28, etc. etc. You don't need a 30mm wide rim to run a 2.35 (though it certainly doesn't hurt either).
Larry
Mountain High Cyclery
[email protected]
In exile
Larry
[email protected]
300 gm heavier than what rim? Does that include the inserts for nipples or not, the 580 I listed?
vs. the 717's he has now. The 823's are now 700g+ with the inserts.
Larry
Hmmm.
loco-****** said:
I hear that the DTs are super soft and dent easily. I ride Alex Supra Ds on a Reign and get along ok.
If you can ride them uphill, why does it matter? Your tire profiles will be better IMO.
I was thinking about trying out the DT 5.1s for my next xc wheelset. I have heard about how easily these rims dent, a few times now.
I am currently using the ex721, which is a little over kill for xc/am use also, but about 60-80 grams lighter per rim, than the 823.
Oh, So Interesting!
mtb_biker said:
xm321 or mavic's new 719 might be worth looking T
I have the F519s (replaced by the 719). Theyre 450g, tough, and I've seen 'em being closed out for $29. I run 2.35 Kendas, Minions, and 2.4 Mutanos on them... I'm 190 lb, theyre on a Giant AC that sees some rough use. 1m jumps are no problem...
If you want UST, look at the 819s.
IMO, theres no reason to run dh rims on trails... 250-300g per rim is a pretty big difference, and unless youre huge, or a trailrider from he11, go lighter, pedal easier...
You don't need a 30mm rim, unless you want to mount big dh tires, too. I'm buying a 2nd wheelset for that, though.
I like wider rims and am currently using Mavic 321's for 2.3 and bigger tires. Wider rims seem to create a flatter tire profile and more rubber on the ground. I believe wheel stiffness is another benefit. I've considered trying the Stan's Freeride rim that is supposed to be 550 grams or maybe the 5.1. To me the 819's weren't wide enough.
Custom User Title
Overkill??? Maybe
I've been running 823's for 5 years now, on my trail and DH bikes, and and put a spoke wrench to them once. They might be a little heavy but I'm not out here to save weight. I ride very aggressive and these wheels just keep asking for more abuse and take like they should. I hade a tire blow out while riding Crabapple Hitts in Whistler and rode on the rim for about 100 feet. I sanded off the burs, no need to re-true, mounted a new tire and I'm still running that wheel.
That kind a confidence is worth a little extra weight when I KNOW that I don't have to even think about my wheels at any time during my ride.
Oh, So Interesting!
yarondot said:
Only 450 g and 29mm wide
I will put pic soon
You mean these?
http://www.universalcycles.com/shopping/product_details.php?id=10967&category=146
Thats 22.5mm, not 29... I've never seen a 28mm plus rim that light.
The F519 / 719 are 450g and 24.6mm... Here's the 519s for $29. I use them for 2.35-2.4 tires. They take abuse well.
http://www.cambriabike.com/shopexd.asp?id=20740
Otherwise, dt 5.1s, Mavic 823s, etc.. would be better for wider rims, but are a good bit heavier.
davec113 said:
You mean these?
Actually that's a mis-print, they are indeed 29mm wide and the weight is accurate. They are very light for the width, so definitely not as strong as most rims of that width.
Larry
[email protected]
Oh, So Interesting!
Hmmm, I (and universal cycles) stand corrected.
Thats pretty sweet, wide and light...
How do you think they compare to the Mavic 519/719 stregnth-wise? Seems like they couldnt be as strong, but I can deal with some truing now and then, my 519s require a little maintnence. Just as long as they won't flat spot real easy...
I want a wider rim next time, too. I thought I'd be sacraficing weight, but if these work out that would be really cool.
1 - 17 of 17 Posts
