1 - 10 of 10 Posts
the air is thin up here..
I'm looking at building a set of aggressive XC wheels... I've got another post going.
Thus far I'm thinking ZTR Arch + Pro II's.
The only "downside" of the Pro II's in my mind is the low number of engagement points. OTOH I'm not sure that paying for a King/i9 is worth it.
Anyway, I'm wondering if it's possible to mod a Pro II hub so it uses something like the Industry 9 design: the 2/2 oppositely phased pawls.
I'm thinking if 2 of the pawls were "trimmed" or "shaved" by half the size of a tooth, the POE would essentially be doubled to 48. I've never seen one of these hubs apart in person... does anyone know if this would be remotely possible?
beautiful noise...
Not sure it'd be possible, much less a good idea. I know for a fact that this hub would get the job done as it's what's on the back of my bike. Just a thought... :thumbsup:
PS: the POE listed is incorrect, it's 72.
nspace said:
Not sure how the mod would work so I can't comment there... but it may be worth looking at how the Hope pro II SS hub is setup. It has 48 POE.
Here is a photo of the inside of one of my Pro II SS hubs.
Not sure why they never carried the same design with 48 POE over to the geared Pro II. I suspect weight savings.
It looks almost identical to the geared ProII except one pair of pawls is offset slightly from the other set, basically making every other one engage (giving 48 POE).
I have been interested in this as well. I haven't found a way to do it yet, but I will be watching this thread closely. Maybe I will try buying some extra pawls and shaving them down.
Is there any way to use the parts from a Pro II SS and mix them with a Pro II geared hub?
Feeding your addiction
Not incorrect actually, they make both 36pt and 72pt versions.
Larry
Mountain High Cyclery
[email protected]
Discussion Starter · #9 ·
Thanks for that, I actually hadn't looked at Hadley before. Looks like a nice hub, pretty heavy though =(
1 - 10 of 10 Posts
