Relayden said:
As many may know, the 08 Talas 32 suffers from the lack of travel issue, that is they don't get the claimed 140mmm but only between 120-130. I read somewhere that PUSH has a fix, but of course if you buy this expensive fork, you don't expect to be having to pay to fix it, when it's clearly defect in design by Fox. Anyone knows if Fox are repairing them?, and please not a La Marzocchi style (that is charging you for warranty service).... So much for this overrated brand....:skep:
Dude, if you are getting 120-130 mm out of your Talas 32, you are lucky! While I agree with your assessment of the fork, what I would recommend are to first reduce oil volume by about 10 mL. If that does not work, switch out the oil to something lighter. I switched to Bel-Ray HVI 5 wt and the fork feels much better this way. Still use the Torco stuff on the Talas side for lubrication. With this mod, I went from ~100m travel with 25% sag to about 115-120mm travel with 25% sag. I have never seen anything close to 140 but don't really care. It is more about the quality of travel and not the quantity.
Also, the most important tip is to take two rags, soak them in Torco oil (and drain the excess oil off) and wrap them around the fork seals overnight. Make sure no oil drips onto your brake calipers. Before your next ride, remove rags and wipe off all excess oil.
I have found this dramatically improves the ride. Other people recommend turning the bike upside down, but I have tried that, and it does nothing like this.
