I had the same questions so I had to try for myself. I have a bike with a ENO WI crank and wondered the oposite is this the best crank for SS? My old XTR M960 should be stiffer right? How about a shimano XT first generation?supersquad3 said:
Here are my findings"
The ENO felt a heck-uva-lot stiffer than the XTR M960 with a Blackspire mono veloce ring. The power transfer to the ENO is solid. I am running it with an IRD square taper BB. The bearing drag on the XTR cranckset was also noticeable.
The star/lock ring system of the ENO is superb for SS although I used steel SS ring bolts on the XTR.
The first gen hollowteck felt ok but the Q factor is way out there. that is one of the things I like about the ENO - low Q factor. Also the chain rings last fairly long for an AL ring.
Go ENO with a phil wood BB or IRD BB:thumbsup:
