As you would imagine, a 180mm rotor is 9/8X as powerful as a 160mm. There's really no sense in changing rotor size if the current setup works fine. Changing pad compound makes a much bigger difference in feel if you must.
A 180mm also harder to overheat and fade but again if yours work fine, there's no need to change.
