it isn't a question of which is better, 11-34 vs. 11-32. The advantage of the wider range cassette is that the lowest gear is about 7% lower than with the 32t.
If your riding situation often has you looking for a lower gear this is the right cassette for you. OTOH if you rarely, if ever, use the 32t cog as is, than the 34t will be used even less often, and you might prefer a better selection of middle cogs with smaller differences between each.
It's a matter of choosing wide range vs. close spacing according to your personal needs. In any case we're not talking a big difference here, it isn't like comparing a 11-34 cassette to an 11-23.
