Terrain Useage: East, TX hard/dry single track (+ downhill jumps) with 50% of the bike useage on paved roads.
Here is the bike I started with:
Frame: 5" TRAVEL dw-link TRAIL FRAME, 1-1/8" ZEROSTACK HEADTUBE, REPLACEABLE DERAILLEUR HANGER
Fork: ROCK SHOX TORA 289 U-TURN, 130MM TRAVEL
Rear Shock: MANITOU RADIUM R, 7.5"X2"
Front Derailleur: SRAM X.7, 34.9MM CLAMP
Rear Derailleur: SRAM X.5
Shifters: SRAM X.5 TRIGGER
Brakes Levers: SHIMANO M485 HYDRAULIC
Brakes: SHIMANO M485 HYDRAULIC W/ 180MM FRONT & 160MM REAR ROTORS
Chain: KMC Z72
Crankset: FSA ALPHA DRIVE, 15-17"=170MM, 19-21"=175MM
Cassette: SRAM PG-850, 11/34T, 8 SPEED
Pedals: CRANK BROS SMARTY CLIPLESS
Bottom Bracket: FSA POWER DRIVE W/ ALLOY CUPS, 73X113MM
Headset: ORBIT Z, ZEROSTACK
Saddle: WTB SILVERADO COMP
Seat Post: EASTON EA30, 30.0MM
Handlebar: EASTON EA30, LOW RISE, 685MM, 31.8MM CLAMP
Grips: N/A
Stem: EASTON EA30, 31.8MM CLAMP
Tires: MAXXIS HIGHROLLER, 2.35" FRONT/2.1" REAR
Wheelset: SHIMANO M495 CENTERLOCK, 32H/SHIMANO M495 CENTERLOCK, 32H/ALEX TD-24, 32H/DT/SWISS CHAMPION 2.0
Weight: 31.6 lbs
Color: KHAKI SATIN
My Observation: the 2.1 maxxis highroller rear tire frequently lost traction on uphill climbs, was very annoying, so more traction is needed (same height style tire preferred because of limited rear-triangle clerance)
New Weight Goal: 25-27lbs with computer, comfortable seat, and wheel reflectors
Initial To Do List
1) Manitou Minute MRD Absolute 2008 model w/ 20mm axle
2) Front wheel replacement ???
3) Use Shimano Flight Deck 6500 computer + Tune Pulsar spoke Magnet
4) remove smallest crank cog gear
5) replace water holder bolts w/ plastic ones where to buy from???
My Goal is to use the best bang/buck upgrades and share all my results with everyone here with pictures too. What do you all recommend based on my ideas so far?
Chain: KMC Z72
Grips: N/A
Weight: 31.6 lbs
Color: KHAKI SATIN
Initial To Do List
