1 - 20 of 590 Posts
Frt Range, CO
It started out as a commuter project, I've since seen the light, internal hub geared bikes are great on the trail.
Motobecane Outcast 29er frame, raw
Salsa CroMoto 29er fork, raw
FSA V-Drive Megaexo Crankset, raw
Shimano M520 pedals
Shimano Dynamo Front hub
SRAM I-Motion 9 rear hub
Mavic TN717 rims
Kenda 2.2" Karma
Avid BB7 front brake
Avid Speed 7 rear brake
Avid Speed Dial 7 levers
ThudBuster ST seatpost, raw
Easton MonkeyLite lo-riser
Assuming the shop does everything right I’m picking my Trance up with Alfine tomorrow morning.:thumbsup:
I gave up a complete 2008 XT/XTR setup that’s lighter and works brilliantly so this better be good, so far on a short road ride it felt great. Black Shimano Alfine 8spd hub with Surly Singleator tensioner and Race Face bash guard. Also had a Hutchinson Toro 1.85/2.15 tire combo put on which explains the delightful amount of mud clearance on the back compared to the Michelin’s.:thumbsup:
First ride was Sunday, with its extras like a Surly Singleator chain tensioner, Race Face bash guard which I probably didn’t need and Sram SS chain which again I probably didn’t need it weights quite a bit more than the old XT/XTR setup but so long as it stays as good as the first ride I wouldn’t change it for anything. The bike feels a bit weird at the moment because I’ve now got a strong, solid feeling rear rim and a front rim best described as flimsy that you can physically see flexing on tight corners but I’ll have that fixed soon and I’ll have some lighter bits to compensate for the weight increase. Anyway, as others have said the shift is so slick you hardly notice it, all the gears feel super smooth, the hub is completely silent which I love, to my surprise it spins freely after hardly any use, it always shifts when pedalling although it does take a little longer if your really pedalling hard, the shifter works in reverse of a normal derailleur type shifter in that you release the smaller lever get into easier gears etc which I think I will be able to get used to, the highest gear is just about perfect for the fast XC riding in my area but I haven’t had a chance to take it to more challenging terrain to try out the lower gears yet. I’m running 18T rear cog and 32T front and I also put a set of Hutchinson Toro 1.85 & 2.15 tires on to improve mud performance over the Michelin dry weather tires previously on there.:thumbsup:
Not exactly the best backdrop, but I was tired after towing the other bike on the trailer. A lot of bash rings from everyone out there so far. I'd have to run one on the inside of the chainring because of the Rohloff chainline, and I'm not quite sure that's legal to do.
faster than walking
I cannot shake the desire to build an IGH trail bike. I built a 1x7 with Saint rear mech to try to take the edge off. Love the bike, but here I am drooling on this thread.
Inglis 29 Rohloff with Paragon sliders.
Curtis updated the frame that I have had since 2002 with a new rear triangle for Paragon sliders and Rohloff cable routing.
Bicycle tire Bicycle frame Tire Bicycle wheel Wheel
Bicycle tire Tire Bicycle frame Bicycle wheel Wheel
Bicycle tire Bicycle wheel rim Mode of transport Bicycle wheel Bicycle part Wheel Bicycle wheel rim Bicycle tire Spoke Bicycle part
faster than walking
You guys rock. I love your bikes. Pursuiter, Wheezee your bike in particular are almost exactly what I want in an IGH trail bike.
Wheezee, you have an aesthetic eye and it shows in your bike. Not often I think of a trail bike as elegant.
Wheezee
Thanks for saying so Cody, much appreciated. If you ever saw me on it, I think elegant is probably the last word to come to mind!
Robin Mather the frame builder, is local to me here in the UK, and I think he made rather a nice job of it.
faster than walking
All please take note that EGF168 dispensed with an XTR drive train to venture into IGH. His thumbs up is high praise indeed.
You rock EGF168.
You rock EGF168.
Why thank you! I was a bit worried the gears weren’t low enough for some of the steep sections but yesterday and this morning I did rides that had some very steep hills and the gears were great, who needs 27 gears when you can have 8 that do just as good job.:thumbsup:
1 - 20 of 590 Posts
