I know competitive cyclist had some I believe that have the ISCG tabs.
fozzy, I've read that the ISCG tab versions are already starting to appear and JensonUSA.com has both the non-ISCG and ISCG version listed for sale with the ISCG version expected within 3 weeks: http://www.jensonusa.com/store/product/FR283H00-Intense+Cycles+Tracer+Vp+Frame+Iscg+09.aspxfozzybear said:looking for a realistic answer pls if poss..
due to update bike come aug. the tracer vp is on the list of replacement options but no tabs will be limiting to my apllication of this frame.
thx
Fozzy, Extra UK were great at getting a demo bike to my LBS. It arrived at LeisureLakes with 48 hours and I took it home for the weekend to play on my local trails:thumbsup:fozzybear said:hmm my LBS would be wise to get me a test bike then
thx
So are you planning on running a Hammerschmidt? If not, the frame really isn't compatible with a chainguide. There are a couple of Threads on here dealing with that issue so no need to start another one here.fozzybear said:your from USA though ?
wonder if the uk importers are getting them with ISCG.. will give them a buzz
thx
nar was thinking of my chain device.. now that you mention it.slcrockymountainrider said:So are you planning on running a Hammerschmidt? If not, the frame really isn't compatible with a chainguide. There are a couple of Threads on here dealing with that issue so no need to start another one here.
If you're not running an HS I wouldn't worry too much about getting a Tracer VP with ISCG tabs.
why isn't compatible with a chainguide? look at tazer vp.slcrockymountainrider said:So are you planning on running a Hammerschmidt? If not, the frame really isn't compatible with a chainguide. There are a couple of Threads on here dealing with that issue so no need to start another one here.
Again, no need to get into this topic here and beat the dead horse to death again. Go back into the Intense Forum and research it on the Tracer and the Uzzi. There are a few recent posts. Pay attention to the canted back position of the guides which is incorrect. Even look at the Tazer picture you posted which isn't quite as bad. If you're still confused, grab a copy of the e.13 set up instructions for the LG1 and then go back to the photo's Mr. Intense posted early on and notice what's wrong. Then look further into and notice he isn't posting shots of the Tracer and Uzzi with guides any longer.dreicha said:why isn't compatible with a chainguide? look at tazer vp.
Well so much for duplicating info so I'll just run with it here again.fozzybear said:RMR thanks for all the info found his setup info for the DRS
http://forums.mtbr.com/showthread.php?t=494825
looks pretty thin at the roller end.
I would keep on Intense for not doing their homework and throwing that crap out the door. Seems a bit irresponsible at the number of changes that went through the lower half of that bike within such a short period of time: lower link was changed, no ISCG, then adding it a short while later. It's great that they can 'adapt' so quickly, but IMO these changes should have been addressed prior to releasing the bike.markcm said:If anyone else has figured out a good chainguide solution, please share.
