So I want to build a custom frame, what I have in mind is pretty close to a Surly Karate Monkey. Single speed, 29er, room for a for a 100mm fork in the future, but rigid for now. The biggest change would be integrated rack, this will be a very urban commuter, but also for inter city trails that have some singletrack areas.
I am in welding school, so I have access to TIG welders, and I am pretty good at making AL stick together via TIG. I read up on AL and it seems to require some lengthy heat treatment, much more than I could do. Something else I saw when reading up was a debate on framefourms.org about precision tables to mount jigs on and check alignment on. This got me all thinking, how much precision do I need to make a bike that isn't crooked? The shop I'm in has drill presses so I can probably acquire the hole saws to do miters, if not there is always the old school way. What I worry about is how to hold the tube in the proper angle while being drilled, Can I take some scraps and some clamps and weld up a "jig" to hold things in place for mitering and later welding?
Should I go with steel because AL needs heat treatment?(I have welded some steel, but I am not nearly as proficient at welding steel tubes as I am at AL tubes)
Are basic measuring tools and some clamps enough to get a frame straight?
Should I just get a karate monkey frame and weld on permanent rack rails?
