1 - 6 of 6 Posts
I'm trying to install the integrated command post into my camber 29 2013.
I cant get the cable to feed through the body.
I'm trying to use the routing in the top tube.
All the pdf's say to use the bottom tube, which I don't have on my bike.
Any advice?
I can see the end of it... it's 99% done... up to the hole edge but can't get it to pass through the bullseye.
This was a terrible idea, of design, maybe I'm missing something.
HELP?!?!
https://www.facebook.com/photo.php?fbid=10203840753839724&set=p.10203840753839724&type=1
Remove any grommets you can. I installed a Reverb Stealth in my Fuel, and I used a brake cable (end cut off) to actually go inside the frame, an go inside the hydraulic line and then feed back out.
This can be an exercise in frustration fo sho.......for the benefit of anyone else needing help, having some dental picks and thin tweezers in your tool box can help guide the cable
1 - 6 of 6 Posts
