...sucked.
Ok I'm not the most mechanically inclined, but I've taken off the regular links and installed before and that was an easy process. However, I ran into some difficulty installing these.
The issue was the top bolts. First off you have to have the Lopes link basically in position before tightening everything down. So the first problem was the top bolts on the rear triangle...basically since everything had to be in place, the tightening process required 1/4 turns of my allen wrench (as opposed to the regular links where you can tighten in full circles since the triangle doesn't have to be mounted). Sure not a biggie. The main issue was the top bolt on the seatube (non-drive side). The drive side bolted in fine, but the f'ing non-drive side bolt had to be pushed around the frame because I couldn't move the triangle as forward since the link prevents forward movement compared to the regular links (the part with the 'lopes' logo only pivots so far down on the frame). So I finally squeezed the bolt in after pulling the triangle piece, while holding the rear triangle up with my leg, whist holding the plastic piece on the bearing because it wouldn't fit if I tried to bolt from outside the triangle.
Regardless, it's in there, chipped the paint on the triangle and stripped the bolt in the process. This thing better be worth it, cuz I don't think it's coming out now.
