hairspraywnikula said:
or alcohol and an air compressor
or buy some grips with bolt on ends
hairspraywnikula said:Im trying to install new Oury grips and none of my old tricks are working...
Anyone know a good way to slide the grips on, but also have them stick and not twist?
Use rubbing alcohol.wnikula said:Im trying to install new Oury grips and none of my old tricks are working...
This guy knows his sh*t. Never heard of this one before. Will try next time I unbolt my Egron's.latedropbob said:forget all those chemicals and such...take a bunch of zip ties and fill your grip with them. stick the grip on the bar with the zip ties evenly spaced within the grip around the bar, push the grip on and pull the zip ties out with a plies...kapow!!! Simple, clean and instant shredification![]()
+1 (3 chars)AzSpeedfreek said:The cheapest hair spray you can find aka. Aquanet!!
Tell me about it, although my "throttle twister" actually involved bolt-ons. I got a pair of those cheap Rav-x ergo grips, and somehow the bolt worked itself loose. But I agree, bolt-ons are a godsend.brianc said:It's not wet enough in AZ for all the masses to see the need for lock-on grips. Everyone should have at least one "throttle twisting" hairball decent in a rain storm to get them home. then they would "see".
