Insanely big post
I know you are all fed up with Troutie and his lights And I was not going to post this one at all
and it was because of a post on CPF which I replied to which let the cat out.
This has been ongoing for a while now waiting for a hipflex and got put aside while the XPE lights were done , and Deestas sort of developed .
The Hipflex will be available very soon so it was time to get it ready to recieve it.
The housing was turned from a 38 mm solid bar for the fins and then the cavity milled out
I am really supprised that my mill has kept going after all the abuse it has had.
Then I glued 4 of the CMC holders together with some plastic epoxy these were then used to get the spacing correct for the 4 MCE M bin
Each MCE was to be wired paralel and then the 4 mce in series.
I milled 2 grooves to isolate the mce contacts and for the wires to run in
Then it was mix some AA epoxy and apply to the back of the MCEs and fit them into the housing
The holders did not press on the MCEs so I had to replace the optics to get some pressure on the leds while the AA set.
Then a quick test on my Nflex test rig it all lit up great .
and this is the Hipflex house all ready , they are a bit large 35.6 mm dia
I have left this oversize and will trim it down whae I see how much space it requires
I am going to have a remote switch so no space needed just cable entries .
Next we come to the bar mounts this is using the bars as heat sink too so they were milled to slot in to the fins for a good contact and will be bolted and AA to get good transfer.
It is just waiting for a Hipflex from George and it will be up and running
It does seem to be pretty bright running off the Nflex @ 1000ma
so each led is seeing 250 ma
and the VF of the lot was 11.67v
How many lumens for 16 emmitters @ 250ma
I will be tempted to get a beam shot even @ 250 ma
Oh The optics Have been chosen because they were the only ones I had left.
and are
1 CMC-RS
and 3 CMC- SS
