I've got out for 3 rides now with the RP3 on my pack and thought I would give others considering the same thing some insight. First and obvious, there is a significant weight savings. I am around the 185lb mark with riding gear on, and had to boost the shock to a higher PSI than expected. I am at 220PSI at the moment, and still bottoming on aggressive XC rides. The propeldal works very well, and the rebound adjustment took a very short time to dial in. If you are looking to shed some weight and turn your pack into more of an XC trailbike, this might be a good solution.
Now for the bad. Even when running the higher PSI, (I get less than 1/2" sag) I can still bottom the shock without doing anything crazy. No real drops of any significance (less than 2 ft, and rolling them rather than dropping them) and I think it lacks the progressive nature that I was expecting. That said, I will continue to use the RP3 on XC rides to help lower the weight, but plan on using my DHX 5 on the majority of my riding. I suppose getting PUSH to change the compression damping or altering it to give a more progressive curve might help, but the DHX is so good I think I'm willing to put up with the weight penalty for the majority of the riding I do.
Questions and comments welcome,
BL
BL
