Assuming the shifter is the correct SRAM 10 speed shifter, the next thing I would check is that the mech hanger is properly aligned.
It's a 10spd and I realigned the hanger.Assuming the shifter is the correct SRAM 10 speed shifter, the next thing I would check is that the mech hanger is properly aligned.
It has 10spd written on the sideHow old is the SRAM XO? I believe older ones come in 9 speed and that wouldn't work on a 10-speed cassette
Should be a no-brainer. But it won't shift to the smallest sprocket nor the largest. Shifts like a knife through butter through the 8 others.
I'm with @jeffrjohns. The indexing in the shifter really takes care of all the middle gears and the limit screws take care of the small and big sprockets/cogs.Are you sure the limits are set correctly. Start with them turned out, they should not affect the indexing and only act like end stops. Sounds to me like they are turned in too much
