I found a relatively simple way of increasing the 40mm travel on the SR Suntour fork. The SR fork is a very simple spring only fork. Of the two legs, the left leg is an empty tube and the right leg has the spring and preload adjuster. Remove the pre load adjuster on the right leg (do nothing with the left as it is not bolted in any way). You may need to use pliers/channel locks to unscrew the adjuster. Once you unscrew the preload adjuster push your fork legs up to present the spring. Remove the spring.
Next remove the 10mm nut on the bottom of the fork leg. The fork legs can now be removed. You will notice that there is a ~1.5" rubber piece on the bottom of the fork. The distance from the top of the rubber bumper to the bottom of the stanchion is what determines the amount of travel.
Use your fingers to unscrew the nut below the rubber piece and remove the rubber bumper.
You can cut the rubber bumper down but I wanted to make sure I wasn't over looking something so I simply made an make shift bumper out of a old rubber hoses and plugs that I had laying around. I made the new bumper about 20mm smaller so the fork should now have around 60mm of travel. Here is a pic of the rubber bumper I made. It's specifically stepped to function progressively (me overthinking).
Notice the new distance from the top of the new rubber bumper to the bottom of the stanchion. This is the new amount of travel
Reverse assemble the fork and have your kid enjoy the new travel.
A couple of observations;
1. The air pressure starts to play more into the ability to compress the fork with the added travel. I'll probably drill air holes in the bottom of the fork to allow it to compress easier.
2. Depending on the outcome of observation 1, I may look for a lighter spring. The current spring is around 60 lbs/in. I may look for a lighter 40 lbs/in. spring.
Hope this helps anyone who likes to tinker. The conversion is very simple and takes about 20 minutes.
