He did make a mistake and ordered the wrong shaft originally, but for the rest, we are speculating and I will give him the benefit of the doubt unless proven different as I would like others to do for me. He's worked on plenty of forks and has successfully swapped air shafts before.
Anyway, I appreciate the suggestions and thoughts on what is going on and want to stay focus on the fork itself.
Here is the original and the 10mm longer one. He's been in contact with Sram. Verified it was the correct part for that fork. They are not sure what is going on either, but have had a rare issue with the port to the Neg air side? They sent a new assembly second day air that will be here today.
Before he called them, he took it apart and checked it over and reassembled. It appeared good, but got worse after a little bit. When he put the original back in, it was fine.
