Sounds like you want...
one of those obses forks they use to run on the Sun bikes ... about 1.5" of travel and then thing never moved ... still dont see the point in those ..but anyways .. I am sure you could find one.
dahouse said:After seeing how flexy and creaky my fork is, I've decided I will invest in a new one.
So this is what I'm looking for in a fork. My current fork is a low travel (68mm) 2001 z5 air set up SUPER stiff. I mean like really stiff, so stiff that even if I put all my weight on it and jump on it, it doesn't go down, meaning I use max 1 inch of travel. I also like the fact that my fork is an air fork because I can pump it up super stiff.
So that's what I want, a fork that I can reduce the travel to 1.5" of super stiffness but a fork that's still very strong. The stuff I ride isn't the hardest, I never huck and I mostly do trials and street, so I need a fork that's light.
So here my 2 options. I either buy an air fork that I can reduce the travel to 1.5" permanately. I hear marz forks are easy to modify like that
Or
I buy an air fork with a lockout and just leave the lockout on permanately.
So do you guys have any suggestions? I hear manitou blacks are über stiff and light but I don't know how to reduce them or if I can make going through the travel harder. A Marzocchi DJ is just way too strong for what I need and is way too heavy.
Before you guys complain about how I should just run rigid, I need to tell you that I have and I find it too hard on the wrists. I like that 1.5" of suspension cause it saves the wrists.
So all your help would be super appreciated! Thanks a million.
Here's a recap on the prereqs for the fork:
Sub 4.5 pounds
Possibility of running it at 1.5"
Stiff as an old man's knees
Air if possible
Somewhat strong
