Seems like every rear rotor of mine gets warped. They have all been 160mm. My recent rotor is warped after 4 hours of ride time. It's an Avid G2.
I am 200lbs and ride a Intense Spider 29er. The front is a 180mm and rear is a 160mm. The narliest downhill section I ride is 3 miles @ -5% grade according to Strava. Strava also shows me at 20mph down to 3mph and back up. There are a lot of tight turns where I need to slow down really quick and then speed back up. I use the front and rear as I approach the turn and then the rear only for any final adjustments.
Do you think I need a bigger rotor or better quality? Something like these?
Shimano Rt86 Shimano RT86 6 Bolt Rotor | Shimano | Brand | www.PricePoint.com
Hope floating rotor Hope Floating Disc Brake Rotor | Hope | Brand | www.PricePoint.com
