take the smaller one off? that sounds like problem solved right thereLickqid said:I'm sick of having two rings up front, I never use the smallest one, even for the toughest trail riding, and it just seems to add hassel. I'm riding a stock 2004 gemini 900, what do I need to do two make those two rings go away?
so that won't screw anything up at all? I'm completely new at this by the way.free rider said:take the smaller one off? that sounds like problem solved right there
im assuming you have a crank puller, you will need to loosen the allen bolt holding your cranks on then pull them off with the crank puller. then take the allen bolts out of the chainring and pll them off and attach the larger one (probably back to the bash guard).Lickqid said:so that won't screw anything up at all? I'm completely new at this by the way.
salimoneus said:or just dremel the little sucker off and toss it, much easier than using a crank puller, and more fun too =)
