I'm running some Panaracer Fire XC tires right now but they feel too beefy for racing. If you only have money for one set of tires to get you through the South/Central Ontario race season, which is it?
How do you like these when it's damp/wet out?bigwheelboy_490 said:Scwalbe Racing Ralphs have been pretty decent as an all around tire. 29x2.4.
I have the '08 Racing Ralphs in 2.1 and they are fantastic in the dry and for racing, but they really suck when the ground is slick/mucky.bbgobie said:How do you like these when it's damp/wet out?
I took mine out once and I got scared...
IMHO, it would depend on what trail you ride. 37 seems reasonable, but if the trail is smooth, you might be able to bump it down just a little more.bbgobie said:Sorry to hijack.
I'm 175 lbs, + 26lbs bike. Running regular 26" Ralphs with tubes. What pressure do you guys think I could get away with? I'm currently at 37psi.
I once had a pump that was 25psi out. Not good.rkj__ said:Also note, some floor pumps have horribly inaccurate gages. My floor pump is off by 12 PSI when measuring at 40 PSI.:eekster: So a reading of 37 on my pump would actually be close to 49!
I take it that was a bike pump?norm said:I once had a pump that was 25psi out. Not good.
I found there's a fine line for the RR performance.. I tried running a higher pressure with the tire, and found that it is indeed super slow and lacking in grip. Drop 10psi, and its a completely different animal. I raced it at Albion today, and it felt as if i was on rails.Johnny Hair Boy said:I am surprised by all the Racing Ralph love. I have a new set of 08's and think they are the worst tire I have ever used. I find them very slow and still have yet to find a surface they will actually grip to. For me the best tire for a good blend of speed and traction (as long as it is not real muddy) is the Kenda Small block 8. My girl friend is running a set now and says they as good as her Nevegals did but roll much faster.
