ashwinearl said:
XC racing
SW-Virginia
hardtail
135lbs
Front disc only.
Not afraid of wrenching but want something easy to work on.
What are your suggestions?
if you want to use the same levers as you have for the rear v-brake, and you want something what feels similar to the rear lever, the avid mechs are great.
quite honeslty, it'll be hard to find something that sets up really easy and has this much power as the avids. i have my avid mechs set up to some ultimate levers and 185/160mm galfer rotors and i am amazed by the power (before install, i placed the pads in my toaster @400* for about 10 minutes, then slightly sanded them). after install, i rode around in the driveway and was doing one-finger nose-wheelies!!!
they are cheap and ultra reliable/adjustable. they are abit heavy but 100g or so doesn't win/lose races...it's the rider, not the ride.
if you're looking for a lightweight hydro...check out the shimano and hope offerings. with the shimano stuff, it's going to be hard to find a front-only system. with the hope stuff, you can get a mono mini or m4 and get a pretty nice, reliable system. the hope lines are also VERY easily trimmable. follow the directions (it isn't hard), be patient, and bleeding will not be necessary (they are pre-bled from factory).
both hope and shimano systems are easy to bleed, no bleed kits needed. you can just use gravity as your friend. with any disc system you chose to look at, a 160mm rotor will be good enough because you are relatively light.
cheers!
