If it wasn't for bad luck...
684 Views 9 Replies 7 Participants Last post by  donkekus
you know the rest.
Thought I hit it right on the head, got freakin' lucky. But, dang...
Running a SS on verts... 40 in the front/18 in da back - street use, I am not that hardcore.
And the chain matches up perfectly! HOORAY!
But - it matches up with two females... not a male and a female.
Am I arsed out?
Any solution?
Not that big of a deal, since I have an ENO on the way... but, ya know.
1 - 10 of 10 Posts
Go to Spicer Cycles website and order a 1/2 link from Gene. Sounds like it should solve your problem.
Just put it together with what you have and go ride it around. If your chainline is good and your ring and cog have decent teeth, that chain's not gonna fall off without some heavy lateral force. You ride on the streets, not some babyhead-strewn downhill that you have to take at > 20 mph.
Ride, try it out, see what you think. Order the half link, but don't let it stop you pedaling while you wait.
No, don't. If it's a half-link too long it will fall off before you get 5 blocks regardless of chainline. I've tried. That is a really loose chain.
Mine never did. Never.
One extra link will be too much I think...
Even a half link will have it a little loose...
But, it's get a half link for now while I wait for the ENO wheel.
1. I wouldn't ride it half a link too long - I've had them fall off numerous times - and only when least convenient - when you're hauling ass into a rocky climb. It happens because you've dropped the tension on the top half of the chain.
2. I've actually gone through the work of putting together an accurate Excel spreadsheet to help calculate the "magic gear" on vertical dropouts. I'll email it to you.
way off
A half-link off means a 2 inch dip in the chain, the lateral force of cornering is enough to lose the chain. :eek:
We'll just have to wait for the ENO!
1 - 10 of 10 Posts
