No they can't.
It's a spring for a Vivid. I doubt they'll have much luck reselling it since they weren't really sure what a vivid was at first.bigpedaler said:What part are you dealing with?
Bikinfoolferlife said:So why are you returning it? You had them order it and now you simply don't want it?
Did you read the OP?I special ordered a part from the lbs and it doesn't fit
I did but the OP's explanation is definitely lacking in detail. Fit? Or other? If it's a Vivid shock and a spring for a Vivid, it likely fits, but doesn't fit his purpose....obviously whatever we say has nothing to do with what the shop can/can't do for him now. To return such a low cost item probably isn't worth it to them...ebay it.JPark said:Did you read the OP?
Yep, and obviously no go.bigpedaler said:The Vivid is a RockShox rear coilover.
Lemme guess -- you were trying to fit it to a one-off coil shock, right?
