1 - 17 of 17 Posts
Elitest thrill junkie
Then why do they become notchy?
The intense guy explains that bearings become notchy or that the races sometimes split. Seems the only way this can happen is if the bearings are staying in the same place most of the time.
Please explain.
Commit or eat sh!t
Mine became notchy because grease had leaked out. After servicing them (didn't need to replace the bearings at all), pivots became real smooth.
Bearings are pressed fit, so there is some load on the bearings, and could wear over time.
So service your bearings and see what happens.
Discussion Starter · #4 ·
Doesn't make sense so far, "notchy" implies that it's "worn in" in certain places more than others.
I skimmed that article, and came away with this....
He used the word "notchy" to describe a bearing feeling when it's geaseless and/or contaminated.
He did state if a bearing fails it can result in a split race.
Greaseless/contaminated bearing do not necessarily mean failed bearing or race.
I didn't see where he stated your quote above. But it is late here on the East Coast. :)
Commit or eat sh!t
I think he is posting on multiple forums to pick fights/troll. I just read his earlier post on the DH forum:
http://forums.mtbr.com/showthread.php?t=479369
If he is such an expert on VPP bearings as he implies in the earlier post, why pose such a question here? :madman: :madman: :madman:
exactly.....does he not think his plastic bushings (journals) are showing wear?
Of course they are, but only if they're being ridden. Those guys spend way too much time behind their screens to ride. Ten thousand posts? Are you fvcking kidding me?
I think Jayem's point is partially correct. bpnics reply is entirely correct. Bicycle bearings wear due to contamination. Rotating bearings such as hubs and BBs tend to wear more evenly. Bearings with a limited range of motion such as pivot bearings tend to degrade more in specific areas. Either can become notchy but contamination will ruin a pivot type bearing faster.
Notchy implies the grease has broken down, the oil component is gone and contamination has made the grease base component hard. The balls roll thru the contamination and have a notchy feeling. Clean the bearing, replace the grease....... notchy gone. I have an early 5.5 prototype frame that still has the original bearings, they simply don't wear out if you regrease once and a while.
Discussion Starter · #13 ·
My bike has needle bearings.
Every other part of his "bearing myths/facts" faq made sense, except where he disagreed with the force being concentrated in a limited area due to limited rotation or just spending most of the time at a certain position and wearing in that way.
but, he didn't.
He said 5-6 ball bearings mainly used, of course depending on the suspension cycling, with the load spread over all 8 bearings on the bike.
From my post in the dh bearing thread....
Clean and lubed bearings will last almost forever. It would be more hours of use than you or I could stand before those 5-6 (or 8, or 80)steel balls break down (or notch), let alone ceramic balls. The failure comes from contaminants and maintenance(cleaning/greasing) not being performed.
...... just trying to help clear up any questions. I work with bearings (nearly every type and application, including journal) in the Hydroelectric industry. Sizes typically range from 1/2" i.d. to 48" i.d.
rain rain go away...
what i posted on the other forum by mistake.....
My take on this is somewhat a bit of what everyone is saying. Sure contaminants will kill almost every bearing. But I also agree that only a few balls are actually taking the load of the bike, hence the use of a full compliment enduro bearings to maximize the surfaces taking the load. The use of bushings will probably offer the most load bearing capacity but supposedly it affects the suspension.
I'm not fully convinced that if you clean and re-grease your the bearings on an Intense often that it will never need replacing. It'll last longer because you've reduced one of the factors contributing to its wear. You still have all the forces going on all directions being aplied to the balls and races and I'm sure that's doing something to wear the bearing. Then there's also the fact that Enduro isn't actually a "real" bearing company. All they manufacture are for the use of bikes and skateboards.... not industrial use. I would say that the steel, the grease and even the manufacturing tolerances they are using are substandard to the ones NSK uses. In addition, having fairly small bearings (smaller contact surfaces to spread the load) mounted on the VPP doesn't help it last longer too. It's a bit of everything.
Thank you Peachy. :thumbsup:
My original argument to J:
Not 80-90%, but closer to 60-70%. And if maintained properly, would last, not forever, but long enough to not justify arguing over. Most people forget their bearing are there, and the deterioration process is accelerated. This is true for all bearings, not just Vpp bikes (Most people just are too busy to flush and lube Vpp bearings more than regularly, which they need because of location).
Assuming the bearings are spec'ed and installed right, they should handle the leverage and weight loads without problem for long enough to satisfy the owner.
1 - 17 of 17 Posts
