1 - 4 of 4 Posts
The Maxle just comes in the normal length.
When I ride hard it comes loose after a couple runs and if there are a lot of corners on the trail it completely winds out. I have had the tire rubbing the chain stays from the Maxle winding itself out 2-3 cm from the dropouts. It is also a bit heavier than the 12mm thru axle.
For now there are no plans for a +10mm/-10mm Maxle.
1 - 4 of 4 Posts
