Doing a spring service on my fork, seals and oils. Re-assembled and went to dial back all my settings and I couldn't even budge my rebound knob. I tried using a longer 2.5mm Allen but it will not turn either direction.
Seized.
So I start looking for replacement rebound damper assemblies and see that there is a 2007-09 part and a 2010-12. My problem is I can't recall what year mine is. It was used and it is either 09 or 10.
I know 09 and 10 are not compatible as they have larger oil ports, is there an easy way to visually verify the model year? Is the bolt on the bottom bigger on the newer version?
Totem circa 2009 or 2010
Started as Air, converted to coil.
Mission Control damper.
Grey/granite lowers.
Do I need item #10 (11.4015.153.000) in the RS 2007 Totem small parts manual
or #16 (11.4015.416.030) in the RS 2012 spare parts manual
Or have I done something else in my re-assembly that is an easy fix?
Seized.
