Talas would match well
KamikazeBikr said:
I'm looking for a new fork my 03 Intense Tracer.
My rear shock is Fox AVA w/o propedal.
Right now my fork is adjustable from 63-108mm.
I like the idea of the windown travel to lower the head angle for climbing.
I'm looking at the Talas and Minute models but not sure if there overkill or tooo much travel for the Tracer...
any advice or comments would be awesome!!
thanks!
My Tracer climbs with the best climbing suspension bikes using a 100mm fork, the only reason I could see to lower the front would be to race and I'd probably lower the rear to 3 inch travel too for better race importance efficiency. I've been very happy with my old Atom like '01 x-fly 100 with coil springs that I haven't really paid a lot of attention to other forks for years.
If you don't have a platform rear shock you shouldn't use platform in front or you'd get twisted up handling. Although the stiction of air springs does produce a relatively mild platform effect. But the Minute would be better matched with a Swinger (or 5th Element) or Romic.
If you want matched air stiction handling then the adjustable Fox Talas or fixed Float fork would balance best well with the non-propedal Fox AVA. If you ever want to go to coil then a coil fork is very neccisary for a good balance with coil rear suspension, with or without platform damping at both ends.
So far I feel that the Tracer rides best without platform damped coil front and rear. But I'm curious about trying a Minute 1, which is a wind down coil fork, with a Swinger coil rear shock if they make the shorter coil shock size, else a Swinger 4 air.
- ray
