I just bought a new headlamp, a Skilhunt H04R. I want to use it on my Fox Flux helmet. So far i've had two ideas for mounting.
First, I just use the original headband like this (on the sides I route the band inside the helmet, I was just too lazy to do it for the picture):
It's okay, but not the best solution. The light is protected nicely which I like. But it's not that stable, it tends wiggle a bit, and it wants to ride up, the visor can't really keep it down. Also, since all the weight is on the front of the helmet, the helmet wants to rotate forward and slide down on my forehead, so I have to lift it up now and then.
I also made a little wooden thingy so I can mount the light on the top of the helmet with reusable zip ties:
It's very stable, the weight is centered. My biggest issue is that our trails are pretty much completely unmaintained, and i'm a 110% sure i'm gonna hit a branch with the light if I use it like this. I'm also not that stoked on putting pressure on the helmet with those zip ties.
Do you guys have any other ideas for mounting this light on my helmet? I think mounting the light on the front under the visor would be the way to go, i'm just not sure how I should do it.
