With all the snow, I have been thinking of a possible snow bike project for next winter. I know I want to do a mountain bike (I already have a cross bike). I know I want single speed (no gears to get gunked-up/frozen). I just don't know what is best. For people with "standard" mountain frames (i.e. clearance up to 2.3 tires), their best option seems to be studded tires. Then there are the wider clearance frames, a la Surly 1x1 (can fit the Nokian 3.0 non-studs). Let's assume the Pugsley isn't an option- it's fairly expensive and I don't really want my feet splayed out that wide with the huge bottom bracket shell. Then there is also the 29" option. My current geared bike is a 29er; I like it a lot. You have increased contact patch, but are limited to a 2.3 non-studded right now (no larger tires made or frames to fit it... no studded tires that I know of wider than the Nokian 700x44).
So what is the best option?
I suppose that on a budget, the best would be to get a cheap 26" frame, slap on a chain tensioner and get some Nokian studs. I like the idea of a 1x1- nice frame, allows me to run the 3.0's if I want (is it better to run narrow studs or wide w/o studs?). The 29er would be more appealing if I could get some nice studs for it. Thoughts?
