You have a new ride oso ? I would say 200lbs,your wieght - 10,or so I have heard,but I may likely be wrong on that.osokolo said:What pressure should I run for RP3... I am 210# with gear... thanks...
i figure... if you as a student could afford an ells and a turner, i'll get another ells...Tarbaby4Ever said:You have a new ride oso ?
osokolo said:i figure... if you as a student could afford an ells and a turner, i'll get another ells...
is that ok with you?
Blue Chris King headsetTarbaby4Ever said:No,no its not,take it back RIGHT now oso !!!! of course I am kidding,what color? what size ? when did you get it ? did you just want a back up ride? have you taken it on its maiden voyage yet ? how does it ride ? I hope you enjoy it and you get years of use out of it ! :thumbsup: Post some pics when its all dolled up !
At about 185#, I run 150 psi in a PUSHed RP3.osokolo said:What pressure should I run for RP3... I am 210# with gear... thanks...
are rocker spacers the same as for 2004 Truth? i can run Romic until i get RP3 back from PUSHing if they are the same...Steve from JH said:At about 185#, I run 150 psi in a PUSHed RP3.
PUSH info is here:osokolo said:are rocker spacers the same as for 2004 Truth? i can run Romic until i get RP3 back from PUSHing if they are the same...
thx
o.
Enough to get the proper sag.osokolo said:What pressure should I run for RP3... I am 210# with gear... thanks...
my problem is that i have RP3 on Truth, and i put 150# in it... Truth leverage is 2:1Jayem said:Enough to get the proper sag.
The Id's leverage ratio averages 2.5:1 with a 2" stroke shock and 2.67:1 with a 2.25" stroke shock.osokolo said:my problem is that i have RP3 on Truth, and i put 150# in it... Truth leverage is 2:1
i believe Id leverage is 3:1 - am i wrong?
following this logic, the pressure in RP3 on Id should be over 200# - that seems to be very high...
right now to get the proper sag i need to put 190# in... kinda high compared to other people...
so the leverate ratio is 2.5:1Steve from JH said:The Id's leverage ratio averages 2.5:1 with a 2" stroke shock and 2.67:1 with a 2.25" stroke shock.
+1...enough to set the sag between .25" & .5" depending on the terrain and required stiffnessJayem said:Enough to get the proper sag.
thanksWhafe said:O., I was at slightly over 155 PSI, give or take a few, thats the last thing I write down about it, I set it, then gave it a tweak on a ride. Just found the piece of card I wrote it on in the toolbox.
Why would the leverage ratio change with a different shock stroke? Isn't leverage ratio determined by frame design and rocker?Steve from JH said:The Id's leverage ratio averages 2.5:1 with a 2" stroke shock and 2.67:1 with a 2.25" stroke shock.
I weight 215# and I ran 165 psi with a '05 Float R.osokolo said:What pressure should I run for RP3... I am 210# with gear... thanks...
Dude, you forgotten my weight already. approx. 190 with gear.osokolo said:thanks
we were talkinga about the leverage ratio of the frame (rocker)...Pic-n-Sav said:I weight 215# and I ran 165 psi with a '05 Float R.
