At this point I no longer believe you when you say you are slow.
Sandbagger
PS: Man up and put some Flows on that thing.
Sandbagger
That's my current thinking too, but I wanted to see if anyone around my size (or bigger) felt confident on I9s w/355s.CRAZY FRED said:I would so much rather have the confidance and the peace of mind ( and of course the stiffness) that comes with the Arch set-up than to go with the 355s just to only save a few grams....But hey, THAT'S ME..................CF.
No, really. I'm slow. I just try to make up for it with expensive wheels.Enel said:At this point I no longer believe you when you say you are slow.
Sandbagger
That's the ticket. I weigh what you weigh, and could not stand my arches on the rigid bike. Too flexy.2TurnersNotEnough said:And yes, you've touched on option C. Build some Flows for the Sultan and use the wheelset I have now on the JET with faster/lighter tires.
If where you ride looks like this pic, then by all means spend the cash and build them. If not, then an endurance event is the wrong time to realize you made a mistake. Personally, if all you are gonna save is 100 grams on the wheel set, then it isn't even remotely worth it. Good luck either way.1-bar said:175-180 geared and rockin 355's on my Jet9. I have not need to true these wheels, not even once. I ride San Juan, Chiquita, Rockit, Holly Jim trail... yada yada. These came direct from I9, so maybe the builder has something to do with it. I will be ordering another set when my Ti Frame is ready.
naw, he rides trails that look like this;Coach417 said:If where you ride looks like this pic, then by all means spend the cash and build them. If not, then an endurance event is the wrong time to realize you made a mistake. Personally, if all you are gonna save is 100 grams on the wheel set, then it isn't even remotely worth it. Good luck either way.
Well, it looks like the tribe has spoken, and it looks like the weight benefit of the 355s aren't worth the tradeoffs. I have a set of WTB/355s and they are the opposite of confidence inspiring, but I thought that the extra stiffness of the I9s might compensate for the flimsier rim. Now the question becomes whether or not the new wheels are built with Flows and put on the Sultan and then use the Arch wheels I already have on the JET9.FoShizzle said:dude, seriously...wtf are you thinking? 355s? did you have head trauma cuz i thought it was just your neck that was sore...dude, no, period
