1 - 7 of 7 Posts
Hi all. I have a set of I9 All Mountain wheels (lefty front) with the DT Swiss 4.1d rims. The ERD is 538mm. I was looking to change over to the ZTR Arch Rim which has an ERD of 540mm. Any issues with using the same spokes?
I asked that very question several weeks ago. The 'official' recommendation I got from Jeff was that it would probably be ok, but they might err toward replacing the spokes ($$$). I don't know the thread pitch they use, but an extra 1mm on the radius (ERD/2) amounts to ~1/2 thread less engagement. And I would guess each spoke has about 5 or 6. Unless you are a hammerhead, I can't imagine that would be an issue.
Anyway, let me know what happens. I was planning to swap rims (4.1d to Arch) in the off season so I'd be interested to hear your experience.
Always ask for longer spokes than they normally use. Chances are better that you can reuse them for the next rim and at $5 a pop, I don't even care if they are too long as long as I can reusue them. This doesn't help the OP but may help others.
Eh? Going long limits the threads of engagement on the initial build (unused spoke threads extend beyond the hub threads) and would ensure a nice rebuild on large ERD rims, but would leave you SOL for smaller ERD rims. I don't see that as a blanket solution.
Discussion Starter · #6 ·
i had previously swapped the 4.1d's for Olympic rims and they worked great. But instead of a light weight wheelset I now want something a little more beefier... The flow rims are the same ERD as the Olympics so I am going to get those instead.
1 - 7 of 7 Posts
