how cheap....?
Because the difference in many is nil or non-existent. There are many running multi-thousand dollar bikes here, using the cheapo Shimano or Campy or whatever sub-$2 cables and bulk housing.scooter916 said:Why on earth would you want to use cheap cable and housing? it will decrease the performance of your brakes!!
unless you meant low cost, than i would recommend the jagwire complete kits, they use a similar set up as der housing and is reinforced.
true but only really if you are talking about coated and non-coated cables. the teflon coated cables are def worth the money because they slide through the housing so much better. less resistance, less drag. and yes, full housings allow the performance of the system to last much longer. try Aztec, they work well for me.scooter916 said:Why on earth would you want to use cheap cable and housing? it will decrease the performance of your brakes!!
I don't know what brand of coated cables you tried JC, but the Aztec Delta brand i have been using for years does not flake off or gum up at all. And the Teflon coating makes a huge noticable difference in performance. I tried to go back to reg SS cables once (cause i needed a cable and its all i had laying around) and I wound up taking it off after 1 ride - too much friction.Jerk_Chicken said:I've never used Teflon or otherwise coated cables that worked any better than regular SS cables. In fact, all the coated cables I used (using alternative coatings) gummed the inside of the housings, thus destroying it, then there are the black and other color teflon coatings that just simply flake off. They provide nothing after a few rides. The flaked off coating ends up inside the housing, or lord knows where, in the case of the exposed area on SRAM derailleurs.
affordable - maybe?backlaboy said:Can someone recommend a cheap pair of cables and housings. I will be using them on my BB7s.
