Not even close! and I do not have to even look. The lengths should be in the 290-300 range. Check your rim spec again.
I come up with 295 (drive side) & 297.jason74 said:Hey,
I used the Dtswiss spoke calculator and I just wanted to dbl check the lengths. I am using a sun cr-18 29er rim and the Chris king ISO rear hub building 3 cross. The calculations I got was left side=246, and the right length was 245mm. Is this even close?
thanks for any help you can give me.
Jason
I'm coming up with 260.95 (261) drive side and 259.34 (260) disc side. CX-Ray's come in even lengths so probably 260 & 262. The only potential problem there is that I've built several sets of 5.1's and I'm finding the numbers that spoke calc programs are giving me are a touch on the long side. I've now been rounding down on most of my builds with those. So, that 262 length may be cutting it close, but you'll probably be o.k. The alternative of course is rounding down to 258/260, that may be cutting it close on the short side but my gut feeling is that with 14mm nipples you wouldn't end up with any exposed threads.tatankainlondon said:Hi!
I am trying to figure out the correct CX-Ray's lenght for following configuration:
DT Swiss EX 5.1d rim (32H)
Hope Pro II front hub
32 CX-Ray Spokes with 14mm brass nipples
3-cross
any suggestions here?
thx
