I only swore once, a nice loud 'f#ck'. So it goes when learning to build. I was brazing up the chain stays on the practice frame and had everything lined up in the jig. The brazing went OK but I could not get the brass to run all the way round because my jig was blocking my torch tip. So I removed the clamp holding the BB shell and continued. A little better. Then I took the frame out of the dummy axle and started chasing the brass around my joints, just to get them perfect. Got one side too hot, the left, and it fell off, hence the cursing. The heat seems to have changed the alignment of the right side still attached so I need to tweak it back, put the frame back in the jig, line everything up and then rebraze the left one. All in a day's fun!
Drew
Drew
